Log Files are not being created
TechGuy
When i specify a log file location it doesnt make a log file there only on the appdata location
The line in the config <LogfileFolder Limit="10">C:\PCP\FreeFileSync\Logs</LogfileFolder>
no matter what i try no log will get created
If there's an error during log file creation you should see an error message when you run the batch job.
TechGuy
So there isnt a way to create a log file even when it succeeds? and when we have gotten errors like this one it still doesnt create one in our path
12/8/2017 - LogFileTest: Synchronization completed with warnings
| Items processed: 0
| Total time: 00:00:00
|________________________________________________________________
[11:55:19 AM] Info: Using non-default global settings:
Copy locked files - Enabled
[11:55:19 AM] Warning: The following items have unresolved conflicts and will not be synchronized:
"test.txt": Both sides have changed since last synchronization.
[11:55:19 AM] Info: Synchronizing folder pair: [<- Two way ->]
C:\PCP\CCleaner
C:\Store
[11:55:19 AM] Warning: Synchronization completed with warning
Or
12/8/2017 - LogFileTest: Synchronization stopped
| Items processed: 0
| Total time: 00:00:34
[11:44:12 AM] Info: Using non-default global settings:
[11:44:12 AM] Warning: The following items have unresolved conflicts and will not be synchronized:
[11:44:46 AM] Error: Synchronization stopped
Gianni1962
FFS always logs its sync activity in the file
C:\Users\%UserName%\AppData\Roaming\FreeFileSync\LastSyncs.log
with recent activity on top.
But you can specify a log file specific for your sync job if you save and execute it as a batch job.
User Manual - Schedule a Batch Job
TechGuy
yes we can see the log there but we are trying to have it in a location that is shorter file path but when we try to specify it the log after the run never mentions creating the log file on error or success
Gianni1962
Sorry, the link in my previous post was wrong, now is correct.
Take a look at the linked manual page.
TechGuy
i have tried that already and still no luck all the settings are correct and the file path was copied right out of File Explorer but no log file
Are you even running a batch sync (and not via GUI)?
