How to keep two remote drives in sync without connectivity?
Is it possible with FFS to compare a drive against a batabase file, then put the files that differ to a USB stick, then move to another place/town, copy the files to the other drive, update the database file, return to the first place, do some work, compare the drive against the updated database file, and so on.
By running similar FFS Two-way variant syncs at both/multiple locations versus a portable disk, e.g. a USB stick, you should be able to achieve what you describe, with the exception that the portable disk would contain all data in the sync and not just the delta/differences.
