PostSyncCommand
oriceon
Hello there.
Is there a way to run a command only if changes occurred after synchronization in target directory?
I want to taskkill a process and reopened it.
Thanks.
You can define a command-line instruction in the "On Completion" line in the Sync Settings (F8) for invoking a user script that might then analyze the FFS log-file, and acts according to what it finds in the log file.
oriceon
It was nice if already has an implementation of that. Sure, i'll made a bat to read Last log and see if found synced files and do necessary.. Thank you for your time.
oriceon
Maybe someone need a bat to do that.
@echo off
setlocal enableextensions disabledelayedexpansion
set logPath=Path_To\Logs
set "lastLog="
for /f "delims=" %%a in ('dir /b /o-d "%logPath%\BatchRun*.log" 2^>nul') do (
  if not defined lastLog set "lastLog=%%a"
if /i "%lastLog%" NEQ "Access" (
    findstr -sip /c:"Nothing to synchronize" "%logPath%\%lastLog%"
    IF NOT ERRORLEVEL 1 (
        echo Nothing to synchronize
    ) else (
        echo Files synchronized
        taskkill.exe /f /im app.exe
        start "" "Your App Path.exe"
exit /b
