[Improvement] Alter the “Run a command after synchronisation” suggestion.
BusterRaid
Suggest changing the “suggestion text” that is offered in the “Synchronisation Settings” dialogue box (“On completion:”).
Example shutdown /s /t 60
To:
Example shutdown /s /t 60 /c “FreeFileSync completed”
Benefit:
Adds narrative to the Windows logs to better identify the reason for the shutdown.
Currently:
The current “suggestion text” causes the below to be entered into the system log:
“The process C:\Windows\System32\shutdown.exe (SomeMachine) has initiated the shutdown of computer SomeMachine on behalf of user SomeMachine\BusterRaid for the following reason: No title for this reason could be found
Reason Code: 0x800000ff
Shutdown Type: shutdown
Comment: “
There is no mention of the app that is propagating the shutdown.
My system:
FFS V9.6 on W10 Pro x64:
Maybe get rid of this box altogether? I'm currently having trouble coming up with good use cases.
ipconfig
NOOOOOOOOOOOOOOOOOOOO!!!
I will use this box to execute a exe that will cleanup older versions!!!
I will use this box to execute a exe that will cleanup older versions!!! ipconfig, 01 Jan 2018, 22:57
This feature should (and will) be included into FreeFileSync directly. Any other use cases?
@Zenju:
I just now replied in another thread of ipconfig that this did not have priority since end 2012.
So I love to read you are now apparently really planning this! Thumbs up!
For other use-cases, please see my 2012 posting referred to in the just referred to reply.
ipconfig
YAIIII!!!
@Zenju: I love your approach. But until then i need that possibility... I will continue the discussion in the other thread...
Other things why i could need that box:
--> After syncing to my NAS i want my NAS to go into standby,
--> or call via commandline a batch/exe to send an email or SMS
--> or trigger my philips hue to change the colour of all lamps into green ;)
cad bloke
Here's a use case ... attrib +r "D:\Deletions\*.*" /s - to makr all the backed-up files as read-only so they can't be altered accidentally.
