This is one of the worst UI change I ever saw... First of all when you deselect more items quickly you always unckeck unwanted items because they come "up" due list refresh and they go "under the mouse" while you're clicking...
But above all suppose the compare finds a bunch of files to copy, but you want to copy only one or two. If you do Exclude All (right click on the columns), how can you re-check the single item you want to copy if it is disappeared with the other??
Exclude Checkbox
