Error with [volume] syntax
cweber50
FreeFileSync allows USB external disks to be addressed via [volume-name] syntax.
This works fine if the USB disk is accessible via some drive letter A-Z, but it doesn't work ("File not found errors...")
if the volume is only mounted into some NTFS mount point (i.e. an empty directory on C/D),
which can be done via Control Panel -> Administration -> Computer Administration -> Data Storage : Disk Administration ...
This behaviour should either be fixed or described.
