FreeFileSync works excellently on my system, with an incredible speed (as I save everything twice for RAID-1-like safety, it has to analyse metadata of 400'000 files. It can do that in less than 2 minutes).
This speed, however, suggests that FreeFileSync works with parallel threads and reads all metadata into memory before comparing data.
If this is so: is there a limit (defined by memory size) to the number of files FreeFileSync can handle?
If so, then this limit should be described in the documentation.
Limits of FreeFileSync
I made such calculations about 2 years ago, but the data structures have not changed (much), so this should still be valid:
FFS can synchronize about 1.7 million file pairs (= existing on source and target side) for each 1 GB RAM available.
I can hardly remember feedback from users having too little RAM for sync, so in general this is not something users should be concerned about.
This info was added to the FAQ.
