Is there a way to be notified if the right side has a newer/only file during an "update" type of sync performed automatically by task scheduler as minimized?
Since the above mentioned scenario is neither an error nor conflict, it does not show up right away.
Shortly, I want to be sure that backup folder is not changed since last sync.
I want to be notified if the right side has been changed during a "update" sync by task scheduler
any ideas please?
