COMPARE 2 TYPES OF FILE.
tweacle
Hi
Im gonna run realtime sync but im trying to do 2 sets of folders at the same time. Both are in "C " drive and "D" drive.
Can I set up a file sync from "C" to "D" drive so it copies everything including whats in the folders at changes or would it be easier to put both sets of folders within another folder.
I.E folder A of which contains folders B & C and files within them. Would it be easier just to do a copy from folder A on "C" drive to folder "A" on D drive but would it also copy over any changes that are made within the folder
Gianni1962
You can have many folders pairs as you want in the same configuration/sync job.
Example:
C:\A\ -> D:\A\
C:\B\ -> D:\B\
C:\C\ -> D:\C\
And so on.
Then should be of help to read the online Manual and to look at the video tutorials.
