my new computer is running nView to handle my graphic card. I've installed ffs 9.8 but when trying to run it, I can see a warning telling that nviewH64.dll 6.14.10.14847 can make ffs to crash and I can't uninstall it.
Is there a way to solve that?
Thanks.
Problems with nviewH64.dll
Same problem here.
A temporary workaround is to install 9.7 version which do not contains the warning pop-up. So far so good for me.
It would be nice if this pop-up stay as a simple warning and don't close the application automatically.
Same problem here.
Thanks. I even hadn't thought of that simple solution !
Updating your nVidia graphics card drivers should fix the issue (as the message states).
I've added a check if nviewH64.dll is actually loaded as a module, which should solve the issue:
http://www.mediafire.com/file/kt44fb8armwdzp0/FreeFileSync_9.9_%5BBeta%5D_Windows_Setup.exe
Can you tell me something about what the problem might be? I'm running the most recent nView available for my (quite old) computer and, although I can work around this problem by using an older version of FreeFileSync, I am wondering whether the nView problem might be related to some difficulties I'm having with some completely unrelated software.
