Hello Zenju,
Why do you change the Sync-Result in the Logfile?
(erfolgreich abgeschlossen, successfully ...)
Is not secure enough or is it cosmetic?
So far, running ffs in Batchmode, after Sync, my bat check the Logfile and search for these text.
Sure, it is possible to change it and check the errorlevel,
but i have to change many sync-batches.
Why Change Sync-Result in Log ...
The status text was changed to harmonize with the one shown in the progress dialog. But it seems the new "Completed" is probably a bit too generic and will be changed to "Completed with success".
Hello Zenju,
Last week I updated also to version 9.8 and I saw that the texts in the logfile is changed. I use a script what looks to this text when an error or the job Completed succesfully is.
Can you give me a list with error messages what can be produced in the logfile?
I look in the logfile for words like:
Successfully
Nothing_to_synchronize
With_errors
Synchronization_stopped
With_Warnings
Thanks.
Successfully
With_errors
With_Warnings
Thanks.
