Status in log file
mhboa
Hello
With olders versions (including 9.5), the log file ended with something like "Synchonization finished successfully" (in french : "synchronisation terminee sans erreurs")
and with 9.8 version the log file only indicates "Finished".
Thus it is very difficult to identify which are the "good" log files and the logs with errors.
Is it possible to indicate again "Synchonization finished successfully" (in french : "synchronisation terminee sans erreurs") ?
Thank you
This has already been changed to "Completed successfully" for the next release.
mhboa
Thanks a lot
