title of folder created from sync?
zamboknee
What's the name of the folder FFS creates for deleted items?
zamboknee
opened the 'last sync log' and found what I was looking for...
[9:14:50 AM] Info: Moving folder "\\s006file02\myname$\My Documents\MooseOnAirCrap\Stager-PerrySmith" to the recycle bin
Where 'Stager-PerrySmith' is the folder I'm trying to retrieve.
I remember seeing the recycle bin specific to FFS but can't remember where it was created to. Can anyone help me here?
It depends on how you have defined the "Delete Files" setting in the GUI Synchronization window (F8).
Apparently now you have selected "Recycle-bin".
If you select "Versioning", you can define your own, FFS-sync specific location.
zamboknee
I didn't define anything though.
zamboknee
I found the folder. It was titled 'RecycleBin.ffs_tmp' and it was in the host computer's 'Recycle Bin'. I'll have another question related to moving/syncing these files back. Will post link soon.
Thank you!
UPDATE: Here's the link to my question I just posted that's related to this issue.
