Version 9.8 MTP error (0x80070072)
hello, I just updated freefilesync to version 9.8. Since the software no longer works. it became impossible to create files on the memory card of my galaxy S8 phone via USB cable. the copy of files under windows works very well. Can I reinstall an old version of freefilesync that worked or does someone have a solution to my problem?
What error messages do you see with FreeFileSync?
ci joint 3 fichiers d'erreurs
- erreur freefilesync_2018-03-04 12_00_09-Arrêté – _2-synchro donnee JMP asus s8 A22_.png (56.35 KiB) Viewed 934 times
- erreur freefilesync 2018-03-04 11_58_32-0 – Lecture en cours ....png (49.03 KiB) Viewed 934 times
- erreur fefilesync_2018-03-04 11_59_31-0,00% – Synchronisation en cours ... – _2-synchro donnee JMP asus s8 A22_.png (91.39 KiB) Viewed 934 times
0x80070072 is ERROR_INVALID_TARGET_HANDLE
Try to create the same folder with Windows Explorer and see if it works there.
it's possible. Everything works with windows explorer.
For more information on the Samsung S8 (memory card) was made with an older version of freefilesync about 6 months ago. This is what updates I made once a month with freefilesync. Today it is no longer possible.
Really? The same folder? It should not be possible to create a folder directly under mtp:\Galaxy S8+\it's possible. Everything works with windows explorer. aster, 04 Mar 2018, 13:01
yes it is possible with windows explorer.
I copy / paste the directory and all the iclus files from my PC ("D: \ USR_JMP1 \ A22") to the memory card of my android Samsung S8 ("This PC \ Galaxy S8 + \ Card \ Android \ data \ Asus \ USR_JMP1 \ A22 ").
It works perfectly.If I use freefilesync it does not work.
"Galaxy S8 +\Card" is obviously not the same folder as "Galaxy S8 +\Stockage amovible"
