Schedule a Batch Job in Windows ... FFS Manual ...
volker01
From the FFS Manual:
https://freefilesync.org/manual.php?topic=schedule-a-batch-job
"if you schedule FreeFileSync to run under a different user account, note that settings (e.g. GlobalSettings.xml) will also be read from a different path, C:\Users\<username>\AppData\Roaming\FreeFileSync, or in the case of the SYSTEM account from C:\Windows\System32\config\systemprofile\AppData\Roaming\FreeFileSync."
And this ist a problem when you use (User-) Global Options in FFS - Tools - Options like "Copy locked files" ...
These Options are saved in the GlobalSettings.xml.
You have to copy Your GlobalSettings.xml to C:\Windows\System32\config\systemprofile\AppData\Roaming\ ... .
Normaly you have no access to: C:\Windows\System32\config\systemprofile\AppData\Roaming\ ...
and you must do that ervery time, if you change anything, or there is an FFS-Update from the GlobusSettings.xml
Or:
When you setup FFS with your User-Account - the globalsettings.xml stored in your user-account and when you run FFS with a Windows-Task, with the User System - then you have start FFS with:
"C:\Program Files\FreeFileSync\FreefileSync.exe" "C:\Users\<YourUserProfileName>\AppData\Roaming\FreeFileSync\GlobalSettings.xml" "<PathTo>\BatchRun.ffs_batch"
Volker01
