SFTP proxy settings
Andel
Hello i have strange issue,
I am using proxy and wehn i go over network wher is no proxy sftp connection is working, when i go over network where i have proxy it does not work, proxy is automatically discovered and also check for updates is working there. but sftp does not want to conenct.
acg
same problem (when connect google drive account). Does ffs work with a specific port that must be opened in the proxy or firewall?
same problem (when connect google drive account). Does ffs work with a specific port that must be opened in the proxy or firewall? ajcg, 23 Oct 2019, 23:36
I've added support for proxy auto-detection when using Google Drive. Can you test if the following version works when you're behina a proxy? https://www.mediafire.com/file/78i92a1cxbooz15/FreeFileSync_10.18_%5BBeta%5D_Windows_Setup.exe
