Failed to activate
Gardener2017
I tried to open my FreeFileSync Donation Edition and a screen pops up that says: Failed to activate FreeFileSync Donation Edition. HTTP status code 500.
Activate via Internet Now does not work.
I pasted the link into my browser to retrieve an offline activation key using this link: https://freefilesync.org/activate-installation.php?ffs=9.9&tx=*************************&hw=984193720&fro=No&hash=SPFFE7ZUCZSDMDIZ29LM. I then get this error: This page isn’t working freefilesync.org is currently unable to handle this request. HTTP ERROR 500
I am online I have a couple of tabs open and they work fine. I closed the Antivirus and tried again. Still have the same problems.
I usually run the program weekly and this is the first time in the years I have used it that I have had this problem.
Thanks for the help!
Just try again, the issue (due to PHP update) has been fixed.
Gardener2017
I did and it worked. Thanks for the quick response and fix!
