HDD eject
Symphony
Hi all,
Hi is it possible to eject the external hard drive Automatically with FreefileSync when saving the data successfully? With the window where example: shutdown / s / t 60 stands?
I hope Someone can Help me
Did you try to enter a suitable "On completion" command in the Synchronization (F8) window?
See e.g here or here.
Symphony
I have already found the window only what I have to enter there so that the program automatically removes the external HDD? Or does not work at all?
That is exactly what I provided the links for in my previous reply ...
Just look at the post marked as "answer" in the 2nd link.
Or the alternatives to RemoveDrive provided in the 1st link.
But, it will take some effort on your behalf ...
volker01
