I have my remote home Win10 PC with Bitvise SSH Server.
I have same music on my client laptop and on my remote server.
I try to do a mirror sync against my remote PC. Both folders have the same content but still
FreeFileSync detects all files are new.
Only after a full sync with remote folder empty is working OK.
I use only file size as comparison criteria.
I just cannot wait to sync all my music first time coz it would take days.
Also the sync speed is terrible slow.
SFTP sync not working with Bitvise SSH Server
I found a workaround. I just copied the content of remote folder into a new one and I use the new one to compare. This solves the problem, don't know why.
This will be "fixed" in the next FFS version with support for parallel file operations.Also the sync speed is terrible slow. alextorex, 15 Apr 2018, 10:33
I saw other commercial app uses P2P protocol for remote sync. It is freaking fast vs FTP.
