FreeFileSync 10.0 not working on XP (bcrypt.dll)
Jegres
Hi
I'm using Windows XP SP3, new FreeFileSync 10.0 not works.
After update have error message:
This application has failed to start because bcrypt.dll was not found. Re-installing the application may fix this problem.
Thanks for the report! I've fixed the problem (another boost bug on XP) and uploaded the new version (without a version increment).
Jegres
Thanks, now works!
p3yot3
Hi
This application has failed to start because bcrypt.dll was not found. Re-installing the application may fix this problem. Jegres, 27 Apr 2018, 05:44
I have the same problem but with Windows Home Server v1, which is a hybrid of Server 2003. V9.9 works fine, but v10 gives me the same error as above.
