Multiple Folder sync
DDillow
Does this software give you the ability to select multiple folders (and their sub-folders) for sync at one time. I would like to select all my main folders, and with one run update my backup drive with any file that has changed or that is new. I don't want to have to select the Documents folder and run a sync, then select the Pictures folder and run a sync, then select my Music folder and run a sync, etc etc.
Will this software do this?
Yes.
