Installation of Version 10 terminates with severe errors
jkillich
I tried to install Version 10. But that is not possible. I get error messages, that several files can't be moved or renamed. I tried an uninstall, but several files were not removed from the disk. According to the error message I do not have the privileges to delete the file although I'm logged in as administrator (Windows, Office 365). I would need the access rights of a "BUILTIN/Administrators".
Any idea what is the root cause for this strange behaviour?
Best regards
Juergen Killich
brjohan
Same experience here when trying to install 10.0 over 8.3 (Windows 10). No matter how I try to rename, with or without 8.3 installed, as user or as administrator. 10.0 does not install on one particular machine. On two other Win-10 machines it installs fine over 8.3 (as user).
Any remedy?
Kind regards /Bror J.
Error messages?
brjohan
I don't have the troubling machine near me right now, but from memory:
If 8.3 is installed, everything looks fine. The install ends telling me that install succeded. But only 8.3 is there.
If 8.3 is not installed, the install ends with a message telling that FreeFileSync directory can not be created, due to such a directory is already present - which it is not.
Gianni1962
What is your antivirus?
The Windows version?
chickpea
I've followed the update link from 9.8 - it downloaded 10.1, *said* it had installed it, but when I started FFS it was still 9.8 - I've even tried to install to a different path, again it claims to have completed the installation, but the new folder is not created and nothing is updated.
