curle_ftp_couldnt_retr_file
manni_metz
i have a problem with the FTP Synchro (Vers. 10.0 donat.). the login is ok, If I let the files list me, comes the following error message: "Das Verzeichnis <my dir> kann nicht geƶffnet werden. curle_ftp_couldnt_retr_file: RETR response: 500 invalid path [curl_easy_perform]"
What can i do?
regards
Manni
You believe this is a bug? Is folder traversal working in other FTP clients?
manni_metz
yes, it works with Filezilla
Do you have some more information, or can provide me with a test login that reproduces the problem?
manni_metz
Excuse me, but it's a private company page. Actually, it's a simple thing...:-) Is the problem unknown? no Idea?
Yes, this is not a known problem.
shrey91
Is there a solution for this bug?
I'm facing the same issue.
CURLE_FTP_COULDNT_RETR_FILE: RETR response: 500
500 Invalid path [curl_easy_perform]
I'm facing the same issue. shrey91, 16 Oct 2018, 13:02
shrey91
Do you have some more information, or can provide me with a test login that reproduces the problem? Zenju, 16 Oct 2018, 13:11
What kind of information do you need ?
Test login credentials would be nice.
shrey91
Which login credentials are you referring to ?
I am trying to access a private ftp site with my credentials.
The credentials and the site are working on Filezilla.
But for FreeFileSync, the above error is displayed.
I think i have specified my issue quite well.
shrey91
The same error is being displayed for multiple sites.
