Action View Has Disappeared
ledruide
Not sure when this happened, but I can no longer preview the proposed sync action in the preview column. Pressing F10 causes the "View Type" icons at the bottom of the screen to cycle, but all it does in the preview column is grey out (or un-grey) the folder view. I'm running 10.0 build 4/26/18 on Ubuntu 18.04. Is this happening to anybody else?
Do you have a screenshot?
ledruide
Is this sufficient?
This looks as if only half of the icons were loaded. Maybe the Resources.zip file is damaged.
ledruide
So I should just reinstall FFS?
Yes
ledruide
Well, a lot has happened since I initially posted, so I can't say for sure, but I think all I needed to do was unzip the Resources.zip file.
