I made a sub-folder in Documents. Free File Sync will not add the files in the sub-folder when I do a sync. What am I doing wrong?
I just added some more files to that sub folder and File Sync is not picking them up. Now I need to check other folders on my PC. Giving me doubts that problems my lie in other folders.
sub folder files not added.
Does this happen with every folder you tested with, or only those in Documents?
I found my problem. I had a filter not to download .pdf files, which is what those files were. The filter I wanted wa PDF, the whole folder and not individual files. I should have examined by setup a little more before posting.
