Easy Batch configuration
jclement
I have been using KarenWare's Replicator, the equivalent of freeFileSync, but it no longer works properly under Win10. One of its advantages is the ease of configuring automatic replication. So would this sort of feature be considered? Automatic synchronization should be easy without having to use complicated system setup.
One way to do this is to have FFF do the batch replication by just starting it. When I start it manually it lists the existing replication setups. All that needs to be added would be an extra option to the batch setup to have the batch file startup at a particular time every day, week or month. FFF could then be started every time the computer is booted.
Alternatively just a flag to run the batch file could be added then FFF would be scheduled, but without any parameters, or with just a parameter to indicate that it should run the batch files. This should be fairly simple. The system setup could then be a standard thing which could be included as a batch file, or better yet done through FFF as an option.
Also a set of check boxes to have FFF run a series of syncronizations would be handy. That way one could just start it and push a button to run all selected syncs.
Is task scheduling really so difficult that it needs further integration?
https://freefilesync.org/tutorials.php
