Could you clarify if the Detect Moved Files feature is compatible with SFTP Source and Local NTFS Target in Mirror configuration?
It doesn't seem to work and I'm not sure if this is expected or there is a bug.
Regards,
Ganchev
Detect Moved Files and SFTP
This should work, assuming that the SFTP side is Linux-hosted (=> proper support for file IDs).
