Where is "open file location" command?
adura
I'm using latest version of FFS (10.1) and not see "open file location" command in context menu. Is it cancelled or forgetted in new version?
thank you...
What do you see in the context menu? From which version did you upgrade?
adura
My context menu is here...
I was use "donation edition" then upgrade normal edition automatically, because my donation edition life was over.
You can restore it via "menu->tools: options"
adura
Thank you, it works :-)
