I would like to know if there is any way to find duplicates in the same main folder, where those duplicates have been relocated into subfolders. For example:
C:/Documents/Files/File.txt
and
C:/Documents/File.txt
This happened after syncing and not realising I had reorganised some parts, so I ended up with the same file in several different locations by mistake. I have over 20 000 files in my main folder, so searching one by one is out of the question.
Thank you.
Finding duplicates after relocating
Thank you. I am aware of duplicate finders, but I was hoping to find a way to do it via Freefilesync instead. If it's not possible, though, I will use the ones you suggested :).
Hi guys!
Is this still the same situation?
I mean to say, a third-party app needs to be used to find duplicate files?
Thanks guys!
Thanks guys!
