How to setup a ftp server that will work with FreeFileSync
markjones68
I have tried FileZilla Server and Core FTP, but can not get either of them to work with FreeFileSync. The both work with Filezilla so I do not know what needs to be done. Please help.
FreeFileSync currently supports SFTP only, so this might be the problem.
hammond_david
It would be great to see support for FTPS (FTP over SSL/TLS) to work with FileZilla Server.
timhfl
I can use Filezilla to reach a server and TLS security is there, but the Comodo certificate seems to be a problem for Filezilla and it asks me to confirm I want it to use this certificate.
Using the same credentials as I do in Filezilla, I try to use FFS to connect. After some delay, I get error messages.
Failed to connect to SFTP server "ftp.zzzzzzz.com".
Error Code LIBSSH2_ERROR_TIMEOUT: Failed getting banner (libssh2_session_handshake)
and / or
Error Code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. (WSAConnectByName)
Is my issue the Comodo certificate? or something else?
mobin01@gmail.com
FreeFileSync work grate with one of my RED HAT Linux server through sftp port, for another server which is actually a production RED HAT Linux server it will not work, always give below message
Unable to connect to "Production Server".
Error Code LIBSSH2_ERROR_TIMEOUT: Waiting for password response (libssh2_userauth_password)"
Is there anyone who can solve this issue?
