Sync errors, FFS 10.2
malcolmp
FFS has been functioning normally, but over recent months now gives error 5 access denied errors when trying to sync across a wireless network.
I am able to write/read/modify files manually across the same network into the same folders that I'm trying to sync, yet FFS fails, see the attachment for a view of the first few errors as an example.
Any ideas why, and a solution?
malcolmp
I’ve now found a workaround. I can map the networked drives in Windows explorer, then FFS those networked drives, and it works...very odd, but at least I’m up and running again.
