How to disable competed alert/notification?
cryofdevil
As title says... how to disable completed alert/notification after sync?
Second question, how to stop filesinc from creating sync.fss_db files?
Delete/rename "Sync_Complete.wav"
Sync.ffs_db is created and *needed* for "two-way" variants or "mirror" with detection of moved files enabled. => Make sure you are using the correct sync variant for your scenario.
cryofdevil
Thanks!
Changing from "two way" to custom, did the trick :)
Disabling "completed" notification was in Sync settings > On completion > close progress dialog.
The best thing is that file sync saves those settings independantly for each session.
Nice one :)
