Option request: delete before copy
DrTeeth
I backup my system to an internal drive and them sync it with FreeFileSync to an external drive. The problem is that any file deletes are done at the END of the process, instead of at the beginning. That creates the situation whereby my half full internal drive, having had several large backup files deleted, fails to be synced to the external drive as that is full! I would like the opportunity to have the deletes happen at the beginning of the sync.
Cheers
DrTeeth
DrTeeth
I'll give that work around a try. Nice to know I am not alone ;-).
Cheers
DrTeeth
I wasn't referring to the workaround (which is not needed), but to this answer: viewtopic.php?t=1711#p6944
DrTeeth
Hi Zenju,
Many thanks. Your help is much appreciated in a very hot and sunny London.
Cheers
DrT
