Automatic AND file (zip) download for Donation Edition?
uwmuc
after an automatic download of the Donation Edition it is only possible to get the zip of the Non-Donation Edition.
Is there a download page for the Donation Edition?
Thank you!
You can 1. run an update check and get options to auto-updater or download manually or 2. use the link from your donation to directly go the donation edition download page 3. use the link from the about dialog to go to the donation edition download page
uwmuc
1. and 3. don't work if it is already installed automatically. 2.: i luckily found the link (in the old mail). Thank you!
1. and 3. don't work if it is already installed automatically.uwmuc, 11 Aug 2018, 08:40
Then you're using the non-donation edition.
