The new warning message for one is annoying. The instructions therein say to :
(See Menu -> Tools: Options; re-save this configuation to remove this warning)
There is nothing I can find at Menu/tools/options that allows me to re-save the configuration. And, when I run the GUI, it appears I can't re-save a configuration that has not changed. I CERTAINLY should not have to edit the configuration and make a useless (irrelvant) change just to change it.
How do I get rid of new WARNING message (10.3) ?
This behavior will change in 10.4: viewtopic.php?t=5562
