I'm VERY impressed by freefilesync!
There are two things I think that would really improve it. On the top where it creates the green graph - make the graphe equal to 100% in the top right corner. E.g. if you are copying 50gb make the scale go from 0 to 50TB I'm not sure why it randomly chooses 2 numbers that aren't 50% and 100% of what you want to copy. Then make it have 3 lines going through so you have 25%, 50% 75% and 100% of your goal being the top right most corner.
The best option IMHO would be the same boxes below the green chart that show items remaining, time remaining and time elapsed have just one more box - Items copied: (e.g. 3,429 (22.2TB)) Sure you could gather that if you take the bottom amount in the comparison and do a the math but it would be so very nice to have that box there with the details handy.
Feature request: better progress graph
This change would give up showing the absolute values on the y-axis label.
Here's the most detailed progress graph discussion so far:
viewtopic.php?t=1511
OK - leave the graph as is - just add that one additional status box and you'll really have improved it significantly IMHO.
