Dear All,
I am completely new with FreeFileSync.....
What I did:
I copied a folder from HDD A to HDD B, which was successful.
The I wanted to check the results with FreeFileSync.
I have used for comparison: File Time and Size.
Result is terrible: The origin folder just includes1% of the files, which are in the origin folder.
If I would synchronize per mirror with the copied folder: 99% of the copied folder will be deleted.
What is wrong?
Thanks for help!
benny
Copied folder to 2.nd HDD, Freefilesync failed
Found the error, was my mistake.
Question is settled.
benny
benny
