Drag and Drop also Error Code 5: Access is denied. (CreateFile)
gyrdleah
OS win 8.1. FFS version 7.5 Build Oct 1 2015 - Unicode x64
Its a bit of a catch 22 situation. If I do run FFS with admin I can't use "drag and drop" but I dont get "*Error Code 5: Access is denied. (CreateFile)" *.
However If I dont run with admin I get:-
*"Cannot set directory lock for "C:\Anydir".
*Cannot write file "C:\Anydir\sync.ffslock".*
*Error Code 5: Access is denied. (CreateFile)"*
I know I can, as a work around, exit programme and rerun with different permissions but its a bit of a fiddle to do so.
Any suggestions would be appreciated.
This is Windows design: Drag and drop does not work when an application is running elevated. Security...
