folder-pair column descriptions FFS 10.4
zikarl
The column-descriptions for folder-pair windows shows after reset only this 2 colums:
| Relative path | size |
This is configurable as you like e.g
| Date | Size | Full Path |
This works on all versions of FFS up to now.
But with FFS 10.4 the colums will be re-arranged after each restart in the following manner:
The path will be always the leftmost column, the rest is on the right side, but Date/Size changes their position to Size/Date.
| Full Path | Size | Date |
Best Regards, zikarl
