Hi there!
Firstly. I love this software, thank you for what you do!
My setup is pretty simple:
2 Windows 10 laptops
NAS (WD My Cloud EX2 Ultra: Firmware 2.30.196)
2 phones running Android 6.0.1
Am currently using RealTime Sync to backup files and folders from laptops, to the NAS. Have the RTS files execute on login/startup, so it's always updating whenever changes are made on the selected folders that are being monitered. Using OpenVPN while traveling allows us to utilize these FFS capabilities from abroad as well.
What I am looking to do is achieve the same capabilities with our Android devices, but am having difficulties finding up-to-date info on how to achieve this.
I know it's not as simple as dropping the FFS and RTS files in the folder locations on phones and NAS, and then use an app to run RTS files on start up on the phones.
Is FFS able to do this?
If so, how?
Again, thanks so much!!!
Sincerely,
Matt
RealTime-Sync for Android 6.0.1
