Folders =
markusoft
I often use FFS for file manipulation, not just backup, but here is my problem - I would like to MOVE FILES
I do a backup as normal, then I say what is = (filter) I want to select all and DELETE from Left or Right side
problem is, FOLDERS are INCLUDED in the =
so here is the problem, I run out of room or quit a job, then want to continue to another disk
I FORGOT to sort by size and have deleted FOLDERS that ARE not EQUAL - as some files made it there and others did not.. now this is because FFS creates all Folders FIRST, well, there is the problem, not all the folders were copied then the second issue - not all folders were = because of 20 files in the folder, I quit at 10 (cancelled), so NO the FOLDER is NOT EQUAL because one has 20 files and the other has 10
I THINK on cancel - FFS should recalculate the FOLDER / file counts and display.
then my = filter would not allow me to DELETE folders that are not EQUAL as they are NOT
