FreeFileSync only mirrors 1 subfolder of many under main folder
I have the source set as ONEDRIVE on the program. A USB Hard Drive as the mirror. There are about 5 folders under OneDrive and it only copies or mirrors one. It ignores the other 4. Any suggestions. ":-Dx thanks! jack
Are those 4 folders really folders, or are they actually links?
If these folders are links, you might need to set the Symbolic Link handling to "Follow"
in the comparison settings.
