synching a file in a folder used to work pretty well up to the current version 10.6.
The include filter contains the files' name (e.g. a.xlsx), the exclude filter ~*.xls* to exclude all temporary Excel files.
Now, running a comparison sometimes work, sometimes not. The results of subsequent different runs may be different. If it works, then it's either x.xlsx or empty. If it doesn't work, the list may contain all files (*.pdf, *.xls* - including a.xlsx) or only part of it (e.g. *.xls* only).
There are two other folder pairs in the comparision and there seem to be an inference between those. E.g. if running each pair separately there are no files displayed. If run together then the beehaviour described above can be seen.
Bug: Exclude problem as of FreeFileSync_10.6
Latest download works :-) Thanks.
PS: I tried to search for new issues in the latest version but the search engine discarded my expressions (e.g. "10.6") because search critia were to common...
