[Feature Request] Pre- and post-commands of a sync-job
thomas.huerlimann
Hi everybody
I saw freefilesync has the possibility to configure a executable file after a job has been completed, for example 'on completed, on success or on error'.
I would have the need to execute a file before the synchronization has been made and another file after the synchronization has been made. This is useable in case you backup database files that need to be in a special hot-backup mode, or older databases that need to be shutdown during the file copy.
Today i use a BATCH file or another script to wrap everything as it has to be. It would be very nice if i can configure pre- and post-commands for a sync-job directly out of freefilesync.
Best regards
Tom
markusoft
1st, 2nd, 3rd, and 4th that.
