logfiles are cropped/truncated? (using 10.6)
bekl
Since a few days, the last line of my logfiles of an (automatic) batch job is not:
"[10:20:51] Info: Completed successfully"
but something like:
"[10:04:37] Info: Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/places.sqlite-wal""
If I start the same job from the GUI, then first "Synchronizing..." is displayed in the window and finally "Completed successful". But also in the "Log"-tab of the window, the last entry is not "Completed successfully".
Is the log cropped? Or is "Completed successfully" not displayed anymore at the end of the log since v10.6?
The sync process itself seems to be successful. I am using FreeFileSync 10.6 [Donation Edition]. (Other jobs on other computers running FreeFileSync 10.5 (free edition) produce logfiles with "Completed successfully" at the end.)
Example for logfile:
__________________________________
|21.11.2018  FreeFileSync-Backup-1
|    Items processed: 10 (4,11 GB)
|    Total time: 00:07:16
[10:04:37]  Info:  Using non-default global settings:
                       Copy locked files - Enabled
[10:04:37]  Info:  Synchronizing folder pair: Mirror->
                       C:\Users\B
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/prefs.js"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/Documents/Outlook-Dateien/Outlook.pst"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/cookies.sqlite"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/datareporting/aborted-session-ping"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/sessionstore-backups/recovery.baklz4"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/favicons.sqlite-wal"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/places.sqlite"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/SiteSecurityServiceState.txt"
[10:04:37]  Info:  Updating file "sftp://192.168.2.14/sync/BE-B/AppData/Roaming/Mozilla/Firefox/Profiles/1an62eoj.default/sessionstore-backups/recovery.jsonlz4"
