[SOLVED] FreeFileSync does not appear in Windows Registry
mardi
Hi
FreeFileSync is installed but does not appears if running
Get-ItemProperty HKLM:\Software\Microsoft\Windows\CurrentVersion\Uninstall\* |  Select-Object DisplayName, DisplayVersion, Publisher, InstallDate | Format-Table –AutoSize
in powershell
any idea ?
thanks.
PS: It is FreeFileSync_10.6_[Donation_Edition]_Setup
You're missing the 32-bit uninstallers:
HKLM:\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall
mardi
Thanks !!!!!!!!!!
