OSX Mojave and RealTimeSync problem
iFab
Hi everyone,
I use FreeFileSync for quite some time (thanks for the great job, guys!) And I've never had any problems until a couple of weeks ago.
Now, I don't know if it's due to upgrading to the new Mac operating system: Mojave, but I've found that when I start RealTimeSync it doesn't start syncing, but it starts FreeFileSync waiting for my command.
I tried to uninstall and reinstall, I tried to create a new RealTimeSync project, but nothing to do, the FreeFileSync window continues to appear.
Someone who knows what happens?
Thanks.
wbloliver
Hi all,
I see the identical behaviour as described by iFab on my Macbook since I updated to MacOs Mojave. Actual Mac OS version: 10.14.1 (18B75), FreeFileSync version 10.6 Build 14.11.2018. Is there any fix or workaround known already?
Best regards
iFab
The post of wbloliver (thanks), reminded me that I had to specify that both Mojave and FFS are updated to the latest version currently available, although I presume it was obvious.
Thanks for the report! The issue with the launcher has been fixed: https://www.mediafire.com/file/hryb6n5yq6rnnuu/FreeFileSync_10.7_beta_macOS.zip
iFab
Now it works again, thanks Zenju.
