Run as a Service
fearless55
I tried this and my PC no longer let me log in. Had to take to Doc to fix for £72. Your help files conflict as ones shows running the app that is Realtime one and another example the green normal one. I chose the realtime one since that is also what the Startup shortcut runs and it made more sense. However, the Task Scheduler caused all sorts of issues. The Doc magically removed references to the two tasks I had set up to clear things up. I followed your examples to the letter - what went wrong? I now have them as startup tasks since I am the only one on the PC.
Some other points for development:
Is there some way to clear out versions of replaced files? Say a 30 days setting or something similar. Otherwise this part of the disk will just grow uncontrollably.
Can I set the idle time when setting up these startup tasks or does it default to 10 secs?
Otherwise, a great tool, many thanks!
