Why does New Sync Include these? Is this just the normal Default Setting? This is a Donor Version, and if I can learn to use it better will Donate more.
\System Volume Information\
\$Recycle.Bin\
\RECYCLER\
\RECYCLED\
*\desktop.ini
*\thumbs.db
The default Include filter is "*", meaning: include everything (that is not explicitly excluded).
The list you are showing is the default content of the Exclude filter.
These items are in the default Exclude filter list, as it normally does not make sense to have these included in your sync.
Thanks Plerry, I'm not getting notifications that I know of so will check the forum settings.
