Display of installed programs
update.freak
in Control Panel, FreeFileSync appears first when sorting by name.
But this sequence is not correct for my installed programs (e.g. "F" comes after Adobe Reader).
It would be great if you could correct this in further updates.
Thanks for your report! Will be fixed in the next release.
update.freak
thanks for the fix in the new update.
